Did you miss your
activation email
Scooters - 50cc
Super 9
Homemade velocity stack
Topic: Homemade velocity stack (Read 1438 times)
TheAmishSasquatch
Sr. Member
June 05, 2015, 05:10:48 PM »
Being in the aviation field occassionally has its perks. For instance having access to exotic materials such as carbonfibre, arimid (kevlar), inconel and titanium. So a couple days ago I was rumaging tbrough a crate of parts and came across a section of inconel exhaust tubing. I took one look at the flange and knew what to use it for. A velocity stack for my scoot!!! I still need a section of rubber or silicone radiator hose and a hose clamp to mount it but heres what I made:
All polished up. I sprayed it with a coat of clear which slightly grey'd the color, but no pics.
I also decided not to waste $15 on an aftermarket fan when I could just paint mine to acheive the same look. I sprayed it with aircraft grade epoxy sptay paint... Should last
[/url]
Last Edit: June 05, 2015, 09:22:43 PM by TheAmishSasquatch
0BARK4322
Re: Homemade velocity stack
June 21, 2015, 09:40:56 PM »
Did it work
ALL STOCK
TheAmishSasquatch
Sr. Member
June 22, 2015, 01:19:35 AM »
Not sure yet. Scoots down atm and Im awaiting parts. If I ever use it, Ill post up. I imagine I wont as it will just lean the mix something fearce. Not to mention suck up dirt and pollen and small mammals. Ill probably just fit it at shows and such.. Home made/ DIY = Instant street cred
Back
