Author Topic: Yager is running rough  (Read 10082 times)
Louder North
Re: Yager is running rough
« Reply #15 on: October 07, 2019, 05:22:12 PM »
Count me in - now there's three of us.  I'm getting the feeling that there's something wrong with the Yager 200i!  I've been through all the systems like you have.  This Yager has only 5,000 miles and runs so rought. Unfortunately, for these machines, there's no diagnostic tools.
JJJ there is a diagnostic tool (more than one actually...).  I have the Kymco diagnotic tool I borrowed from de dee... but no DTC codes show up.  The issue is not one that the diagnostic tool can pick up.  The other tool, other than your ability to trouble-shoot (!), is to use your mulitmeter across the leads on the pump itself and measure the resistance.  It is supposed to be 1 ohm give or take 0.1 - rather precise measurement.  Mine was 2.7 ohms - too much resistance = too little fuel pressure when  it counts.  Fuel pump is now on order.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
« Reply #16 on: October 07, 2019, 09:25:51 PM »
A stuck vent valve will not show on any diagnostic analyzer nor multimeter.
Louder North
« Reply #17 on: October 08, 2019, 08:58:49 PM »
Thanks.  I have haven't checked that - do you recall where in the plumbing the vent value is located? (there are a lot of fuel vent
lines all other the place!).
10,000 km
bought used in 2018
1986 BMW R80
alfadan
« Reply #18 on: November 22, 2019, 05:10:37 PM »
When my 2010 was misfiring at high rpm I replaced the coil and the counter (they both have to be replaced together) and has been running smoothly ever since, about five thousand miles.  I'm up to 18K miles now and the scoot shows no sign of slowing down.
The counter being the magneto that tells the coil when to fire.
« Last Edit: November 22, 2019, 05:17:45 PM by alfadan »
Louder North
« Reply #19 on: November 26, 2019, 05:31:35 PM »
Thanks alfadan but I've replaced both of those items and it made no difference.  I determined the fuel pump was out of specification (resistance was too high) so I ordered another and am waiting for it.
10,000 km
bought used in 2018
1986 BMW R80
« Reply #20 on: January 02, 2020, 11:34:59 AM »
 ;D ;D  I have been riding my Yager-frost all fall,  been by Jims place twice , it still running well,.  I take a run to Morrisburg  Ont. by the seaway a few times ,.
« Reply #21 on: April 20, 2020, 05:56:49 AM »
I have been switching scoots b v 350 to yager-frost 200,  both running very well,  on 3rd tank of gas on the yager , same on the b v 350
Lucky scooter
« Reply #22 on: September 28, 2020, 09:39:10 PM »
I have this issue after I left my Yager out in the rain and it got knock down to the right side recently. Not sure if the battery's wire loose or other issues. I added fuel cleaner, it helped a bit but not much better.
