Author Topic: LED bulbs  (Read 1804 times)
mrmike
  • Syuracuse, NY
LED bulbs
« on: June 14, 2015, 10:00:40 AM »
In January 2013 I bought 2 LED tower bulbs. I installed them on my GTI300 as running lights where the European turn signals go. I noticed the other night that they now are different levels of brightness from each other. Some of the strips of lights no longer work so the brightness levels vary. Is this the normal way these bulbs wear out, or do I have another problem? Any experiences, thoughts, or suggestions?
« Last Edit: June 17, 2015, 10:54:33 AM by mrmike »
Chris0381
Re: LED bulbs
« Reply #1 on: June 14, 2015, 11:17:09 AM »
Lights are usually made in China now were quality is second priority if that. And yes; I took 2 back to walmart and re-bought them because of this issue.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
mrmike
  • Syuracuse, NY
Re: LED bulbs
« Reply #2 on: June 17, 2015, 10:58:45 AM »
UPDATE:  Talked to the folks at SuperbriteLEDS today. After talking, we believe the LEDS burning out was probably caused by normal riding over rough roads, potholes, curbs etc. Scooter vibrates more than a car would. They lasted me 2 1/2 years, so I ordered replacements and we'll see how these do.
Re: LED bulbs
« Reply #3 on: June 17, 2015, 11:27:57 AM »
l also put in some led running lights in my LIKE200i.....but too soon some portions burned out...and worse -- some portions started flickering, mimicking a turn signal!!!
Removed them and put in some reg amber 5W bulbs a year and a half ago. Still working fine....and pretty darn bright from the front.
bman
Re: LED bulbs
« Reply #4 on: June 18, 2015, 02:09:41 AM »
The running lights on my Yager are very close to the headlight, making it seem like a single light.
I wanted some low wattage led lights with a different color contrast and found these.
http://www.walmart.com/ip/Sylvania-168-194-2825-LEDriving-Bulb/29029256
Nice crisp white light, good contrast to the halogen headlight.
Not sure about the brightness in daytime, but they light up the road nicely at night.
Re: LED bulbs
« Reply #5 on: June 18, 2015, 01:48:45 PM »
   x2. At times vibration from the scoot will do damage to the light socket it srlf.
0BARK4322
Re: LED bulbs
« Reply #6 on: June 20, 2015, 07:20:38 AM »
That's the bad part about strips. they seen to blow out one at a time
ALL STOCK
