Author Topic: Resetting CELP error codes  (Read 10679 times)
bman
« on: June 14, 2015, 09:28:25 PM »
Trying to track down a P0115 error code I found a lot of confusing methods to clear the codes.
The simplest way is to open the throttle fully, turn on the ignition, release the throttle after CELP light comes on
and let the trouble code lights cycle 5 times.
« Last Edit: June 14, 2015, 09:31:04 PM by bman »
Yager200i
Re: Resetting CELP error codes
« Reply #1 on: June 16, 2015, 09:24:03 AM »
Here's the Diagnostic Trouble Code (DTC) list (thanks goes to MotoRandy123 for posting this), for future reference:
1 P0217 Engine overheating
2 P0335 Encoder fault
3 P1120 TPI adaption fault
4 P1121 TPI range fault
5 P1122 TPI velocity fault
6 P0560 Battery voltage range fault
7 P0110 Air temperature sensor fault
8 P0410 Idle air bypass valve fault
9 P0505 Idle speed adaption fault
10 P0251 Fuel injector fault
11 P0350 Ignition fault
12 P0230 Fuel-pump relay fault
13 P0219 Engine max over-speed fault
14 P1560 Transducer power supply fault
15 P0700 CVT threshold exceeded fault
16 P0115 Engine temperature sensor fault
17 P1561 Temperature gauge fault
18 P0650 Check engine lamp fault
19 P1410 CO potentiometer fault
20 ?
21 P0105 Manifold pressure fault
22 P1110 Angle detect sensor fault
23 P0136 O2 sensor circuit malfunction
24 P0141 O2 heater/O2 sensor circuit malfunction
25 P0171 Close loop fault
« Reply #2 on: June 17, 2015, 01:29:41 AM »
  is the error code good for all scooters , or just your scooter I have a 300i downtown,
bman
« Reply #3 on: June 17, 2015, 02:59:10 AM »
The error code numbers are the same. The number of blinks is different.
http://www.enmoto.com/enmotoonline/downloads/Specifications/Kymco/Reparaturanleitung%20Kymco/Downtown_300_i/13.pdf
Page 11 and 12.
2wheelfun
« Reply #4 on: June 25, 2015, 08:35:15 PM »
If you can't download that try firefox browser, had this issue earlier.
ScooterWolf
« Reply #5 on: July 13, 2015, 07:18:13 PM »
Any codes for resetting a digital clock from military time to AM/PM mode?
-Wolf
