Author Topic: With sidestand down startmotor cranking the engine?  (Read 1004 times)
guile
« on: June 18, 2015, 06:07:54 PM »
Can anyone confirm what the X normally does when you start the engine with the sidestand down.
I need to know to confirm wether there is an issue with switch in the sidestand or not.
Does the startmotor crank the engine (like mine does) without firing up?
Re: With sidestand down startmotor cranking the engine?
« Reply #1 on: June 18, 2015, 06:15:45 PM »
Crank but no start, the same as your handle bar kill Switch.
guile
« Reply #2 on: June 18, 2015, 06:17:55 PM »
Thanks.
Are you sure about the kill switch? Normally the kill switch well.... kills everything
« Reply #3 on: June 18, 2015, 07:23:15 PM »
Thanks.
X500 *should* still crank with the handle bar kill switch in "kill", don't fully remember though. If the side stand kills the motor its doing it's job.
guile
« Reply #4 on: June 18, 2015, 07:25:19 PM »
Thanks
sissy mary
« Reply #5 on: June 21, 2015, 04:57:11 PM »
With side stand down engine cranks but does not start. When running, if you put side stand down it kills the engine just like kill switch.  :-*
