Author Topic: oil pump  (Read 1108 times)
1martyg
oil pump
« on: June 20, 2015, 12:42:25 PM »
Will oil pump not being tight cause air leak?
2009 super9
« Last Edit: June 20, 2015, 01:07:22 PM by 1martyg »
Triesandluth
Re: oil pump
« Reply #1 on: June 20, 2015, 01:58:18 PM »
Not tight to the case? I can imagine so being that the gear is ran off of the crank.  But I have no definite yes or no.  How has it become loose,  if you don't mind sharing?
Sent from my XT1080 using Tapatalk
1martyg
Re: oil pump
« Reply #2 on: June 20, 2015, 02:49:13 PM »
Not tight to the case, I left it loose while changing reeds, afterwards it would only run decent with the air/fuel screw all the way in.
Re: oil pump
« Reply #3 on: June 20, 2015, 03:29:09 PM »
All the way in is all the way lean, not a sign of air leak. The oil meter has an o ring so if its pushed in there is just likely sealing ok.
Triesandluth
Re: oil pump
« Reply #4 on: June 20, 2015, 08:04:57 PM »
Then are we going towards possible problems from the reed changing?
0BARK4322
Re: oil pump
« Reply #5 on: June 21, 2015, 09:05:44 PM »
He might want to manual put oil in tank until problem is fixed....what you guys think
ALL STOCK
Triesandluth
Re: oil pump
« Reply #6 on: June 22, 2015, 12:17:17 AM »
Might be other problems that will need sorting out as well.  And like b&l stated,  it may have a proper seal.  I have two bolts holding mine down,  if I remember correctly,  but one was missing when I bought it.  Never been a problem so far.
