Did you miss your
activation email
Scooters - Big Bore
Xciting 500
Engine light
Topic: Engine light (Read 6272 times)
telejojo
Newbie
Engine light
June 21, 2015, 10:42:17 PM »
I bought a 2009 500r and it runs great and full of oil but the engine light stays on. I guess some day I will take it to a dealer and see what the code is saying but everything seems fine.Has anybody had this happen?
bongoman
Sr. Member
Re: Engine light
June 22, 2015, 02:29:52 AM »
The oil service light comes on every 4000 miles to remind you to change oil. Depress the rubber button on the right side of dash and it will reset.
2009 Xciting 500
2015 Lance Cali Classic 150
telejojo
Newbie
Re: Engine light
June 22, 2015, 11:09:38 AM »
It only has 3400 miles on it.The light is on the left a little pic of an engine the same in a car.
telejojo
Newbie
Re: Engine light
Reply #3 on:
June 23, 2015, 11:03:49 AM »
Got a repair manual and by the number of flashes and it is the TPS,but it's running fine so I'm not going to worry about it.
xsel777
Re: Engine light
Reply #4 on:
June 30, 2015, 04:44:11 AM »
A reset will most likely sort it out, as I had same issue when I got my XC 500 EFI.
telejojo
Newbie
Re: Engine light
Reply #5 on:
July 02, 2015, 11:08:18 AM »
How do you reset it?
xsel777
Re: Engine light
Reply #6 on:
July 02, 2015, 02:16:09 PM »
There is a recessed rubber button on dash. Use a thin stick, push in firmly, hold it in continuously for about 1 min. There, fixed.
If it comes back, problem is more serious, workshop time then.
telejojo
Newbie
Re: Engine light
Reply #7 on:
July 04, 2015, 01:24:01 PM »
Does it need to be running or just on?
xsel777
Re: Engine light
Reply #8 on:
July 04, 2015, 05:20:16 PM »
My mistake, that is oil light procedure.
CELP reset procedure is:
Have a watch or phone with seconds.
Scoot ignition off
Red engine off switch must be ON.
Scoot on centre stand
Side stand up.
Procedure starts now:
Turn ignition ON where dash lights light up.
Wait 10 seconds and then
turn throttle fully open.
After another 10 seconds,
turn throttle fully closed.
CELP flashes x 2 after 5 seconds.
Engine lamp(CELP) is now reset.
Last Edit: July 04, 2015, 05:45:32 PM by xsel777
telejojo
Newbie
Re: Engine light
Reply #9 on:
July 05, 2015, 09:52:46 PM »
It would'nt work battery was low so I put in a new battery and it worked.Thanks................
xsel777
Re: Engine light
Reply #10 on:
July 06, 2015, 04:14:55 AM »
Great news.
Hopefully it never returns.
OaklyJava
Newbie
Re: Engine light
Reply #11 on:
October 22, 2016, 12:24:21 PM »
Sorry could you explain to me turn throttle fully opened & closed
Sent from my SCH-I605 using Tapatalk
sissy mary
Re: Engine light
Reply #12 on:
November 06, 2016, 06:15:07 PM »
Yes key must be on, or have bike running to re-set.
OaklyJava
Newbie
Re: Engine light
Reply #13 on:
September 10, 2018, 06:29:59 AM »
Thanks![emoji8]
Quote from: sissy mary on November 06, 2016, 06:15:07 PM
Sent from my SM-G950U using Tapatalk
Back
