Did you miss your
activation email
Scooters - 50cc
People 50
Bendix
Topic: Bendix (Read 813 times)
emanuel_v19
Newbie
Bendix
June 26, 2015, 05:11:45 PM »
Hello all,
So i was replacing the belt and rollers and what not and removed what was needed to be removed. When i put everything back i started hearing this ticking noise in the CVT. I assumed it was the bendix thanks to my prior research on here with knowledgeable people like you guys. So i decided to remove the bendix and see if that was the culprit of the problem. Turned out it was. The ticking noise was gone. However, i would like to have the electric start since im using all kickstart right now (and it kinda sucks because the kickstand doesnt retract to its original position, maybe something is broken? spring? it was working good for about 5 kicks then it stopped retracting) This being said, what can be wrong with it? broken bendix? it was working fine untill i opened it up to install the new parts. Here are some links to the bendix pics. Not sure if they will be any helpful.
https://www.flickr.com/photos/25146305@N06/19174437432/in/dateposted-public/
https://www.flickr.com/photos/25146305@N06/18557698164/in/dateposted-public/
Please let me know what you guys think! thank you all.
You never know do ya!
Close enough to get the idea!
Re: Bendix
June 26, 2015, 05:50:56 PM »
Same for this post. Just keep the one. We can all find it.
emanuel_v19
Newbie
Re: Bendix
June 26, 2015, 08:15:40 PM »
How do we delete a topic? ....
Re: Bendix
Reply #3 on:
June 26, 2015, 10:44:58 PM »
On the top right of your post it has a couple options... One of them is "Remove".
Just tick the check box, and then tick remove.
Back
