Author Topic: Dismantling my Like 200i  (Read 1531 times)
Rasta_scootah
  • 2014 People GT300i 1,500 miles / past 2012 Like200
« on: July 01, 2015, 05:36:12 PM »
:) Hey Guys , I'm taking the front inside leg shield apart on my Like 200i in order to install maybe 4 bright blue LED Lights , and replace the original incandescent front maker bulbs also with an LED ... I've gotten all the screws out from the white and black colored parts and even removed the floorboard bolts , but , something seems to still be holding things in place ... " HELP !! "
What am I missing here ??
Arrows in the photo mark where I intend to drill and place 3/4" Blue LED Lights ...
Re: Dismantling my Like 200i
« Reply #1 on: July 01, 2015, 06:24:17 PM »
After all the screws are out, and that 10mm center bolt.....it just says to take them apart.
Edge Clips?
Rasta_scootah
« Reply #2 on: July 01, 2015, 09:04:35 PM »
:o Oh ! I was trying to pry off the inside Leg Shield & it wouldn't budge !  The front one was stuck on tight too .. ! I was about to give up put it back together & go for a ride , ... How do you pry off that Front Shield ??
« Reply #3 on: July 01, 2015, 10:07:35 PM »
Somebody help this guy out!
I've never been in there......
(there is a post from a year or two ago of a fellow inside that cover, messing with lights or horn or some darn thing....search in the LIKE200i threads. ?
Good luck,,,when you get it sorted - post us the instructions with pictures please.
Rasta_scootah
« Reply #4 on: July 01, 2015, 11:12:30 PM »
;) Yea, Lights ... , ...
LidoCA
  • I LIKE chinese plastic.
« Reply #5 on: July 02, 2015, 02:42:36 AM »
 Take out all of the exposed screws on the inside front panels. Pop off the outer center panel as in stigs picture. unbolt front outer shield. Remove screws from front outer fender, the black section under front shield. Outer shield will pop off. The inside panel is screwed in place from the inside. Once the outer front panel is out, you will see the screws. Many, many tabs. Be careful.
 If a tab breaks, you can crazy glue it back in place easily. I have replaced these panels on my wife's Like.
« Last Edit: July 02, 2015, 02:46:31 AM by LidoCA »
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
Lucasan
« Reply #6 on: July 02, 2015, 01:44:11 PM »
By the looks of this, I'm guessing that taking all the panels off of my Like will be more of a project than I thought. I had designs to repaint it over the winter. I'm hating the the LX colors my ex chose right about now.
