Author Topic: Gt maintenance 10,300 miles  (Read 2339 times)
boo
« on: July 04, 2015, 11:42:45 PM »
As some of you know from my previous post, on first try I could not get my variator nut loose. Today I decided to try again.
My local shop had put the nut on. Apparently they used Red Loctite.
I heated the nut with a propane torch. I broke one of the hardened steel studs off my holding tool while trying to remove the nut.
I was determined to get the damn thing off.
Out comes dremel tool. Using small cut off wheels, I cut diagonal slits in the nut and finally managed to get it loose and off. What a pisser!
Fortunately, I did not damage my crank threads.
Installed new drive belt and 14gm Dr pulley sliders, and a new air filter.
Had to use air impact wrench to remove variator and clutch nuts.
Had to use same to tighten both nuts. I used a small amount of Blue Loctite.
I prefer to use torque wrench but, I had no choice this time. My holding tool was broke.
Took it for a short run and everything seems ok
On yea, clutch pads were glazed. Used Emery cloth and de glazed them.
ps: Never use Red Loctite on your variator or clutch nuts.
« Last Edit: July 06, 2015, 01:25:59 PM by boo »
300GTI black
Pro 2A - member GOA & NRA
Re: Gt maintenance 10,300 miles
« Reply #1 on: July 06, 2015, 03:38:15 PM »
You really NEED to either fix your holding tool or make one to get the right torque back on those nuts!
Wait a minute! Did you use the impact wrench to put those nuts tight? You're good if you did. Don't worry about the holding tool or the torque wrench. Two, three, four-- here comes B & L and Zombie!
« Last Edit: July 06, 2015, 03:41:59 PM by CROSSBOLT »
« Reply #2 on: July 06, 2015, 03:52:52 PM »
  on your holding tool get the right size bolt and drill a hole , insert bolt and all fixed,.  de dee
mrmike
  • Syuracuse, NY
« Reply #3 on: July 06, 2015, 08:24:49 PM »
Boo
Let us know what you think of those 14g Dr. Pulleys vs stock rollers. I changed mine at 550 miles and didn't ride enough on the stock rollers to compare.
boo
« Reply #4 on: July 08, 2015, 02:09:06 AM »
Boo
Will do mrmike.
300GTI black
boo
« Reply #5 on: July 15, 2015, 01:38:18 PM »
Tool has been repaired and should not have that problem again. I reinstalled with Blue Loctite and new variator nut.
« Last Edit: July 17, 2015, 12:58:18 PM by boo »
300GTI black
