Author Topic: Headlight Not Getting Voltage Nor on Panel Checked Fuses All Other Lights Work  (Read 954 times)
zml661415
I have a 2007 Kymco People S200 when I switched the battery to a new one, the 2 headlights don't come on anymore nor does the switch/the light on the panel doesn't illuminate. I tested voltage at the light plug/socket with the scooter on (AC, Power since not from battery right? I used both settings) and there's a green wire, brown wire, and white I think. Only had voltage from brown wire. Previous owner put LEDS under the current stock light those run of battery and come on and look like they are powered by the brown wire. I think green is ground since I saw the ground scooter wire is green.
Could it have something to do with the battery change? Is there any other fuses it could be besides the ones by the battery. I know the lights only come on when scooter is on. Both headlights are out, so I dont think its the bulbs, I get no power at socket, maybe I need to check connections to the stator? Could it be the CDI, or Voltage Regulator? I feel like those wouldn't fail randomly like that, I feel its more likely I yanked a wire when switching the battery? Is that even related?
Thanks in advanced to everyone for all the guidance.
