Author Topic: can someone post a pic of where to find brake pads on the bike?  (Read 997 times)
spikebites
The picture in the manual is horrible, and I know this should be an obvious thing, but I can't seem to find the exact location of where my brake pads should be.
Maybe I am missing it, or overlooking what should be obvious, but if anyone has a better/clearer picture of what the pads look like on the bike, I would greatly appreciate it.
thanks
Re: can someone post a pic of where to find brake pads on the bike?
« Reply #1 on: July 08, 2015, 11:08:12 AM »
Your scooter might have the same construction issue that my Forza does: rear pads are impossible to see without removing stuff.
They are in your calipers, obviously.....but may be hard to see the wear groove.
Somebody with this scooter and a camera  -  -- jump in here....
« Last Edit: July 08, 2015, 11:33:08 PM by Stig »
« Reply #2 on: July 08, 2015, 02:06:02 PM »
  look at your brake discs and you will see the caliper if you use a flash lite you will see the pads,  I have over 60,000 km.s on my downtown with same pads , and still look OK.  as your pads wear, the brake fluid will go down a little, and the brake leaver will pull in a little more,.  so check your site glass on the brake fill up on the handle- bars,.
spikebites
« Reply #3 on: July 09, 2015, 04:15:53 AM »
60,000 kms and they are still going strong?  that's comforting and great!  and thanks for the tip on the brake fluid.  This makes things a lot easier and assuring.
