Did you miss your
activation email
Scooters - 125 to 300
People 250
hand grips
Topic: hand grips (Read 2701 times)
ddarkone7
Jr. Member
hand grips
July 08, 2015, 03:19:14 PM »
Has anyone upgraded or changed their hand grips for some thicker ones, if so which ones. When I ride now my left wrist gets sore. I tried loosen my grip, but I think the small pot holes is the problem
Big Texas
ScooterLar
Full Member
Re: hand grips
July 08, 2015, 04:02:41 PM »
Rather than replacing the OEM grips, you can buy foam grip covers that slide over your existing grips. I installed them on my wife's and my Like 200's and they work great. Also, you may want to replace the stock handlebar end weights with heavier ones. The heavier the end weight, the less vibration you'll feel.
Last Edit: July 08, 2015, 04:04:26 PM by ScooterLar
2005 Grand Vista
2006 Vespa LX 150
2009 Grand Vista
2006 People 250
2013 Like 200
2013 Like 200 LX
2012 Genuine Buddy 170i
2009 Genuine Buddy 125
ddarkone7
Jr. Member
Re: hand grips
July 08, 2015, 04:15:30 PM »
thanks, which bar ends did you use, oh never mind, i just realized you said a Like, but thanks, about to order the foam grips, never thought about that.
Last Edit: July 08, 2015, 04:18:35 PM by ddarkone7
Big Texas
ScooterLar
Full Member
Re: hand grips
Reply #3 on:
July 08, 2015, 04:34:05 PM »
They are off a Kymco People 250. You can order them from your Kymco dealer. Here's a pic of the small OEM end weight on my Like 200 and the heavier People 250 end weight on my wife's Like 200. If you order longer (heavier) end weights, make sure you also order the longer mounting screws.
Last Edit: July 08, 2015, 04:36:54 PM by ScooterLar
2005 Grand Vista
2006 Vespa LX 150
2009 Grand Vista
2006 People 250
2013 Like 200
2013 Like 200 LX
ddarkone7
Jr. Member
Re: hand grips
Reply #4 on:
July 08, 2015, 05:22:48 PM »
ok i have the grips, now i need some heavier ends, i wonder if the ones will fit off a exciting 500, and what size to get if i go aftermarket
Big Texas
ddarkone7
Jr. Member
Re: hand grips
Reply #5 on:
July 08, 2015, 05:51:02 PM »
do you know the size of the people 250 bar end weights? cause i can get some universal ones
Big Texas
ScooterLar
Full Member
Re: hand grips
Reply #6 on:
July 08, 2015, 06:28:40 PM »
They should fit a standard 7/8" handlebars. Which ever ones you buy should have the same "shoulder" as the original ones. The "shoulder" is the side of the end weight that goes into the end of the handlebars.
2005 Grand Vista
2006 Vespa LX 150
2009 Grand Vista
2006 People 250
2013 Like 200
2013 Like 200 LX
ddarkone7
Jr. Member
Re: hand grips
Reply #7 on:
July 08, 2015, 08:50:05 PM »
thanks, i appreciate the help, i ordered some grab on
Big Texas
Packrat1
Newbie
Re: hand grips
Reply #8 on:
February 25, 2017, 08:10:56 PM »
Just installed the Grab On Grip Covers on my 2006 People 250. The correct size was the 4.25" grip cover that fits 1.25"-1.50" OD at least on my model. Did have to use some sharp scissors to cut a small amount off. Sprayed hairspray on the entire inside of the grip and slid them on. They fit perfectly. I bought them off Amazon through Longhorn Moto.
Back
