Author Topic: Whitch cabel do i need to cut, to remove the CDI restriction  (Read 3263 times)
andrej20899
My scooter wont go faster than 55km/h that's 34 mph, and when I'm going uphill it looses much of the power, so i want to cut the CDI rev wire to make it faster. The scooter is stock, i haven't changed anything on it. So question is, witch wire needs to be cut so that the CDI doesn't get rev information?
Re: Whitch cabel do i need to cut, to remove the CDI restriction
« Reply #1 on: July 10, 2015, 04:27:41 PM »
First off, what scooter do you have? Also try and post in one place, it will get answered (faster if anything) in one spot.
Roytheroach
« Reply #2 on: August 20, 2021, 11:32:01 PM »
Get a gy6 cdi and find some wiring diagrams
