Did you miss your
activation email
Scooters - 125 to 300
Super 8 150
Adjusting the Idle [VIDEO]
Topic: Adjusting the Idle [VIDEO] (Read 1103 times)
wkreps
July 11, 2015, 12:11:14 PM »
Just a little diddy on how to adjust the idle (viewer requested).
Wayne
skishades
Point 'em and Pray
Full Member
Re: Adjusting the Idle [VIDEO]
October 23, 2015, 05:07:44 AM »
The idle is even easier with the seat pan out. My question is, does the carburetor have an air/fuel mix screw?
I will ski till Hell freezes over... then I will have no fear of death.
wkreps
November 30, 2015, 04:46:13 PM »
This is referred to as the pilot screw in the service manual. Same thing right? Has a cap over it and has a special head on the screw. If so, then yes it does.
Wayne
nix30101
Newbie
Reply #3 on:
January 19, 2016, 02:11:46 AM »
what type of adaptor is used to adjust the air/mix screw?
wkreps
Reply #4 on:
January 20, 2016, 02:04:03 AM »
Quote from: nix30101 on January 19, 2016, 02:11:46 AM
I think it is a "D" shaped screw driver but not sure. I have heard of people using a dremel tool to grind a notch into it and then just use a regular screwdriver. I would not be brave enough to try that as it may just break the head off alltogether. Maybe someone can chime in here with a little more definitive answer.
Wayne
Back
