Did you miss your
activation email
RIDING MY SCOOTER AND ALL OF SUDDEN
Topic: RIDING MY SCOOTER AND ALL OF SUDDEN (Read 3056 times)
0BARK4322
December 01, 2009, 02:23:22 AM »
JUST OUT RIDING MY SCOOTER AND ALL OF A SUDDEN I HEAR HIGH REV'S----OH OH----HELP----WHAT IS IT
ALL STOCK
Shaka
Re: RIDING MY SCOOTER AND ALL OF SUDDEN
December 01, 2009, 02:31:36 AM »
Can you give more detail? Were you accelerating, cruising, throttle position? Was there a loss of power or did it take off? Did it stop on it's own? Will need more info to try and troubleshoot.
axy
December 01, 2009, 09:49:20 AM »
Well, if you suddenly experience high revs on a cvt, I would say that something has snapped in the transmission...
Kymco Agility 125 2008
DEPeople
Newbie
Reply #3 on:
December 01, 2009, 05:01:29 PM »
That sounds like when My belt snaped
Shaka
Reply #4 on:
December 01, 2009, 05:40:48 PM »
First thing I thought of was the belt snapping also. Did the high revvs remedy itself? If it did it's probably not the belt.
You never know do ya!
Close enough to get the idea!
Reply #5 on:
December 01, 2009, 09:30:11 PM »
He just finished his own cvt work! A little time to open the case will tell.
Shaka
Reply #6 on:
December 01, 2009, 10:42:21 PM »
In that case, I would think that the variator or clutch nuts came loose.
0BARK4322
Reply #7 on:
December 01, 2009, 11:20:45 PM »
AHHHH---I FOUND OUT WHAT HAPPEN, I OPEN UP THE COVER AND SEEN THAT THE NUT ON THE CRANKSHAFT/PULLY WAS LOOSE, I GUESS WHEN I CHANGE THE BOSS I DID NOT PUT IT TIGHT ENOUGHT, A SIMPLY TIGHTING AND IT WAS BACK TO NORMAL--THANKS ALL
I AM HAPPY NOW---THANKS GUYS
Last Edit: December 01, 2009, 11:29:08 PM by 0BARK4322
ALL STOCK
Shaka
Reply #8 on:
December 01, 2009, 11:31:17 PM »
Awesome, that's what I suspected! Hopefully no damage was done!
0BARK4322
Reply #9 on:
December 01, 2009, 11:41:14 PM »
NOPE---I RODE IT FOR A 38 MILE TRIP TODAY, I RIDE ALL YEAR ROUND & YEP, YOU WAS RIGHT --THANKS
ALL STOCK
Reply #10 on:
December 02, 2009, 01:02:16 AM »
Glad to here it works! How do you do that scrolling thing??? COOL!
0BARK4322
Reply #11 on:
December 02, 2009, 01:32:46 AM »
JUST CLICK ON MOVE
ALL STOCK
Reply #12 on:
December 02, 2009, 04:31:11 AM »
Cool!!!
0BARK4322
Reply #13 on:
December 02, 2009, 11:46:05 PM »
I WONDER IF I SHOULD PUT SOME OF THAT LOCKING THREAD STUFF ON THE BOLT SO IT WON'T COME LOOSE AGAIN BUT NOT SURE IF IT WILL HEAT UP--HUMM
ALL STOCK
Reply #14 on:
December 03, 2009, 12:21:19 AM »
The nut that is on there should be a "capture nut" Meaning it is slightly deformed so as not to back off. They are similar to nylok nuts in the fact they are not meant to be re-used. A new nut should be installed each time you remove one. Like a gasket or a hose clamp. If you do use a locktite compound, use Locktite BLUE. It is made to be removable. The RED is for permanent installations. The heat on the crank end is not enough to be a factor.
Back
