Author Topic: Location of people s 125 regulator  (Read 3171 times)
Abner_Bjorn
  • 5280 Scooter Group Rides on FB
« on: July 11, 2015, 07:03:03 PM »
Can someone please tell me where the rectifier is located on a S 125?   Thank you!
Less chit chat, more riding.
Re: Location of people s 125 regulator
« Reply #1 on: July 13, 2015, 03:01:02 AM »
Front cover, crest piece.
Abner_Bjorn
« Reply #2 on: July 13, 2015, 03:18:25 PM »
Thank you BettinANDlosing.
Any idea what the DC volts should register at the battery on a revved engine?
« Reply #3 on: July 13, 2015, 04:38:09 PM »
Idle should be anything above static battery voltage, pretty much anything higher than 12.6v at idle. And with a pretty good rev, should get past 13.5v but be at very very least 13v, and ideally go to 14v.
« Reply #4 on: July 13, 2015, 04:38:54 PM »
There was a recall for the charging system on the S200, and possibly the 125. Call and ask your dealer if they can check it out, recall "should" be covered even out of warranty.
Abner_Bjorn
« Reply #5 on: July 13, 2015, 05:30:59 PM »
Man I love this forum!   Thank you!
