Author Topic: Variator belt age  (Read 996 times)
mclark999
Variator belt age
« on: July 12, 2015, 06:14:08 PM »
Is it just the width of the belt that determines replacement or does age matter?  I just bought a 2007 People that only has 1000 miles on it, but it is 8 years old.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
beermak
Re: Variator belt age
« Reply #1 on: July 12, 2015, 07:31:32 PM »
Over age the material gets old so it might last much less.. get it running strong and then adress the belt just to have a reliable commuter
gosku
  • Start me up!
« Reply #2 on: July 13, 2015, 08:30:26 AM »
I recently changed mine belt for the first time. I rode it for 7+ years and 10,000 kilometers. I did not measure it, since I was doing some CVT upgrades and replacing the belt was "just in case" type of thing, but it looked quite OK. I did not notice any signs of rubber aging, no cracks and so on.
I would inspect & measure yours. It might not be the top priority thing to replace.
Kymco People S 50 2T 2008
Tecnigas Next-R Pipe
Malossi torsion controller 2512828
Malossi rollers 7g
Michelin City Grip front + Heidenau K66 rear
« Reply #3 on: July 13, 2015, 04:41:46 PM »
They last pretty good, but just out of habit I replace any belt that's over 5 years old. The older they get the more noise they make, and since the rubber hardens it adds friction to an already high friction design of transmission.
