Author Topic: Anyone know the Downtown's GVWR?  (Read 4022 times)
ScooterWolf
« on: July 14, 2015, 03:53:18 PM »
I'm trying to calculate the scooter Gross Vehicle Weight Rating, but can't seem to find any info in the owner's manual.
-Wolf
bluesin
  • 2012 DT 300i
Re: Anyone know the Downtown's GVWR?
« Reply #1 on: July 14, 2015, 10:29:41 PM »
You mean how much weight it can ( safely) carry?
ScooterWolf
« Reply #2 on: July 14, 2015, 11:08:49 PM »
Exactly. Trying to figure that out.
-Wolf
RubenC
« Reply #3 on: July 15, 2015, 01:17:02 AM »
Owner's Manual net weight: 411 pounds.   Found on page 49
From the Great Nation called Texas. Oops I mean the Great State called Texas
ScooterWolf
« Reply #4 on: July 15, 2015, 03:06:01 AM »
Yeah, I saw that. But is that the total net (wet) weight, or the GVWR?
When applied to this formula it doesn't work out.
GVWR: 411
Scooter Dry Weight: 367
Scooter Wet Weight (add App. 40 lbs.) 40
367 + 40 = 407 (dry weight plus weight of fluids - oil, gas, etc ... )
Available load capacity: (GVRW - Wet weight) 411 - 407 = 4 lbs.
Since the GVWR can't be 4 lbs, this leads me to believe that the Net weight of 411 in the owner's manual is the Downtown's actual wet weight, and not its GVWR. From what I've seen the GVWR is listed on the bike with the VIN number. I was hoping someone might now that actual number.
The above formula is from this site:
http://powersports-blog.denniskirk.com/2331/harley-davidson/how-to-calculate-your-bikes-load-limit/
-Wolf
ScooterWolf
« Reply #5 on: July 16, 2015, 01:22:41 AM »
Found the Downtown's GVWR = 768 lbs.
GVWR: 768 lbs
Scooter Wet Weight: (add App. 40 lbs.) 411 lbs.
Available carry capacity: (GVRW - Wet weight) 768 - 411 = 357 lbs.
Rider (me, with the weight of helmet, jacket and boots): 191 lbs
Average passenger (weight of helmet, jacket and boots): 165 lbs
Total: 356 lbs
Additional carrying capacity = 357 - 356 = 1 lbs.
If I've done any math wrong someone correct me. Does this seem off for the Downtown? It seems it can barely support two adult passengers with nothing left for cargo such as a security chain, tool kit, or even a six pack. Given, one can go over the maximum carry capacity, but I'd worry if that figure edges past 50 pounds or more. That will cause distress on the shocks, tires, etc ...
-Wolf
« Reply #6 on: July 19, 2015, 07:49:43 PM »
Where did you find this, Wolf?
« Reply #7 on: July 19, 2015, 10:12:11 PM »
Wt. on rear tire ,  270 lb,s   with me on it at 220 lb,s ,. =  362 lb,s   rear tire capacity 617 lb,s,.  that will leave 255 lb,s for the pile on,   up to tire capacity,.  as the pile on is over the rear tire,.  my rear tire is a city grip,.  front tire capacity is 520 lb,s    power pure, your tires could be a little different,.  my GVW. is 349 KG.  = 769 lb,s
« Last Edit: July 20, 2015, 08:29:42 PM by de dee »
ScooterWolf
« Reply #8 on: July 20, 2015, 12:08:51 AM »
Crossbolt. I found the GVWR rating on the plate on the lower left side of the scooter along/below the driver's running board. The formula is from this site,
De dee, is the information you have the one that's on the sticker placed on the gas cap panel? If so, that makes more sense than my formula
-Wolf
« Reply #9 on: July 20, 2015, 02:11:55 AM »
the tire rating is on all tires,   the rest of my ratings are done with my scales,  and I have tools in my top box,.  de dee
ScooterWolf
« Reply #10 on: July 20, 2015, 12:04:57 PM »
De dee, thanks. I'll take a look at my tires and see what they say.
-Wolf
8eeman77
  • Work hard, ride safe
  • I'm a scooter loving Apiarist
« Reply #11 on: August 02, 2015, 12:54:53 PM »
What's this pounds rubbish?! Kilograms or nothing  :)
The Kymco DT 300i ABS is the best scooter you can get. I love it's carefree automatic ride. I would like to see kymco make a 600cc version but no heavier then the 300. I would buy it for sure
ScooterWolf
« Reply #12 on: August 02, 2015, 01:57:00 PM »
No one in the US thinks in metric. Uses, yes, but thinks, not always. Sorry, just never took.
-Wolf
« Reply #13 on: August 02, 2015, 10:23:40 PM »
walk in to home depot and ask for plywood 122x2480x 6 mm.  or  (2x4 )  5 x 10 x 2480 mm.
        4 x 8 x 1/4 inches     give me metric numbers and I have to convert every time,.  A Canadian  de dee
« Reply #14 on: August 21, 2015, 10:10:32 AM »
Mid to low 300's is what I found for a whole lot of scooters  and bikes....no matter their engine size.
Adding together the load capacity (printed on the tire wall) of the two tires is not the carrying capacity of a scooter. This figure will be higher than the bike is built to carry.
EVERYONE , however, says factory gives much lower numbers than the bike can actuallydeal with......to avoid law suits.
Still, I go by that sticker by the VIN.
And is one reason why I went up from a Forza to a Burgman.
