Author Topic: Belt size issues  (Read 1831 times)
flextrainer
Belt size issues
« on: December 01, 2009, 03:24:59 AM »
I'm having trouble cross referencing my belt. I need a new one, but i can't find one with the numbers I have. The belt has bando 23100-KEB7-9000 on the belt, but I looked two different places and the both cross referenced to two different sizes. One was 729-18-30 and one 838-18-30. Does anyone know which one is right? I find it odd that the same part number would be used for two different sizes.
« Last Edit: December 01, 2009, 03:28:43 AM by flextrainer »
Shaka
Re: Belt size issues
« Reply #1 on: December 01, 2009, 04:31:34 AM »
I don't know why your coming up with two different sizes for the same number, but the one you need is the 729mm one.  I checked the Malossi equivalent and it is 743mm, probably to accommodate their larger variator.  When I ordered mine I physically measured it first by wrapping a tape measure face down around the original to verify.  You should be able to measure without removing the belt from the pulleys, just pop off the cvt cover.  By the way, 838mm just sounds waaay too long!  Here is a link to the Malossi if you want it, I've had great luck with my Malossi belt on the zx50!
http://www.provoscooter.com/scooters/malossi-x-kevlar-belt-kymco.html
