Author Topic: carb and vacuum lines  (Read 792 times)
spencerlrsn
« on: July 15, 2015, 06:17:00 PM »
so im having trouble starting my 2t people 50 after removing and cleaning the carb to install bigger jets.. im almost positive its because the carb isn't getting any gas.. when i open the drain screw at the bottom of the carb, no gas comes out.. i can take the fuel line off the carb and manually apply a vacuum to the vacuum line to get fuel to flow extremely well from the fuel line.. but when i put the fuel line back on and then suck on the vacuum line again, im positive no gas is going into the carb bc even with the drain screw open, no gas flows out.. what can i do to fix this?? ive cleaned the fuel input hole on the carb twice now..
