Did you miss your
activation email
Technical | How To
Reading a spark plug....NGK
Topic: Reading a spark plug....NGK (Read 983 times)
July 19, 2015, 02:20:50 AM »
http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp?mode=nml
Found this to be helpful over the years
West Tennessee, USA
Re: Reading a spark plug....NGK
July 19, 2015, 07:59:00 PM »
One of the best ones so far. Thanks!
Yager200i
Sr. Member
July 20, 2015, 02:33:10 AM »
Here is the spark plug related stuff I use.
Jeopardy4100
Jr. Member
Reply #3 on:
July 20, 2015, 05:13:44 AM »
Stig & Yag, thanks for the informative references. Had just pulled the plugs on our boats kicker. Just a bit rich according to the pics. Thanks again
Yager200i
Sr. Member
Reply #4 on:
July 22, 2015, 07:44:33 PM »
It might not be too rich, your plug might be too cold of a heat range. Unless you're using the heat range recommended by the manufacturer, then it'd be too rich.
Jeopardy4100
Jr. Member
Reply #5 on:
July 23, 2015, 08:28:30 AM »
It is the proper plug. After reading your response I checked with boat mechanic. He said Honda motors used primarily for trolling will show a slightly richer burn. Guess we will have to open her up a few times.
Back
