Author Topic: Changing transmission/gear oil... how will I know I have filled enough?  (Read 2102 times)
spikebites
Okay, I managed to get the oil into the tiny hole, but I am afraid I might not have enough, or maybe I put in too much.  It asks for 0.23L, but a lot of it dribbled down the side of the hole, so, is there any way of checking to make sure I have enough in there?
Theres no dipstick, so is there any visual indication I have used enough oil? or if I am not using enough?  is there any signs? sounds?
« Last Edit: July 22, 2015, 01:27:09 AM by spikebites »
beermak
Ill drain it and refill it with a syringe with the right amount. Thats how i did it before several times
boo
the only way
« Reply #2 on: July 22, 2015, 01:31:01 PM »
To do it right is to drain completely when hot and install correct amount with a syringe.
300GTI black
Pro 2A - member GOA & NRA
spikebites
But, will there be a burning smell if theres not enough oil?
or will there be leaking if theres too much oil?
You should put in the correct amount, and that will be it. No worrying at all.
kneeslider
If not wrong, you can't really over fill with gear oil, the inlet hole is located so that sets the physical limit of how much gear oil can go it. So just fill to .23' or till the inlet hole over flows.
2019 Yamaha X-Max 250
Hate to argue, Kneeslider, but what you said is incorrect. You will overfill using that method. Voice of experience! Gotta put the right amount in with a syringe. I put a mark on the plastic jug where the level should be after the right amount is squeezed in. Most jugs of gear lube have a tapered spout that fits in the M6 hole.
kneeslider
Would a slight over fill on the gear oil cavity be bad?
not really bad but I had a lot of oil on my air filter, thats where the gear vents too,.
kneeslider
Talk about the air filter. I haven't even inspected it since the day I picker her up.  :P
