Author Topic: Super8 Electrical Issue  (Read 8165 times)
wkreps
Re: Super8 Electrical Issue
« Reply #15 on: August 01, 2016, 01:56:47 PM »
Well, maybe, Wayne. You might have found a wire broken INSIDE the insulation. Also consider a terminal lug or other crimped-on terminal like inside one of the plug shells. I know you found something! Now ya gotta figure out what it is!
If it was a wire broken INSIDE the insulation wouldn't unplugging and replugging back in each of the connections while key was on give me the same response (no power)? That is what I did and it kept power the whole time.
I ask the ? cause I'm just trying to learn.
Wayne
« Reply #16 on: August 01, 2016, 02:30:16 PM »
Does yours have a light control module?
wkreps
« Reply #17 on: August 01, 2016, 03:40:42 PM »
Yes but I believe that only controls the headlight.
Wayne
« Reply #18 on: August 01, 2016, 04:01:09 PM »
That's what it is SUPPOSED to do but some of the other threads seem to indicate when it goes bad it affects a lot of other stuff. I think it was Bettin & Losin' said they are junk and he bypassed the thing. Don't remember which threads had this but it seems there were several. And I may have misunderstood!
