Author Topic: Replacement Fuel Line For an Agility RS 125  (Read 835 times)
Stokesy64
  • magtapVE
« on: July 24, 2015, 01:52:32 AM »
Hi Everyone I am relatively new to the forum....Live in Tasmania Australia and have been reading with interest some of your very informative posts. I have a query re Fuel Line for an Agility RS 125.... Any suggestions on a better Quality fuel for the above scooter would be appreciated as I have been having trouble with the standard line spitting occasionally and would like to replace it with something a little more robust...... I have already done away with the standard clips and replaced them with the small screw type clips that we use for cars etc......Thanks in advance
Whimpy
2wheelfun
Re: Replacement Fuel Line For an Agility RS 125
« Reply #1 on: July 24, 2015, 06:20:38 AM »
General purpose fuel line from auto stores should work. Just get the right size, here it's in 1/4in, 5/16ths, 3/8ths etc. Remember if it's a tad small it's rubber and will expand, key is a tad small. Not too big either. Route it away from heat sources as much as you can.
Doc Wheezer
  • Silently riding armed through the Mojave Desert.
« Reply #2 on: July 24, 2015, 05:21:28 PM »
Make sure your fuel line isn't metric, everything else is, including the jis (Japanese Industrial Standard) screw heads. They look like Phillips but there is a slight difference and they can be stripped real easy using a Phillips screwdriver.
http://www.vesseltools.com/hand-tools/screwdrivers/jis-japanese-industrial-standard/view-all-products.html
Stokesy64
  • magtapVE
« Reply #3 on: July 25, 2015, 09:12:33 AM »
Thanks very much for the very informative replies  really appreciate your input.....Will look to source some general purpuse line from a couple of my local stores.....Thanks again ....Whimpy :)
