Author Topic: Noises  (Read 1719 times)
mnpugdog
Noises
« on: July 26, 2015, 02:16:24 PM »
Ok 2 newer noises coming from my DT that I know you guys can help me with.
The first one is related to the front brakes. When applied I hear a kinda sandpaper sound coming from them. Is it pad related or disk related?
The second one is coming from the rear by the exhaust area. Only during acceleration do I hear what sounds like something is rubbing. A kinda light rub of metal maybe. If I let off on the gas it seems to go away or is so quite you don't hear it. Belt related maybe? or something else?
Re: Noises
« Reply #1 on: July 26, 2015, 08:29:21 PM »
Front brake pads could be worn to the metal by that sound description. How many miles? Would have to be a bunch since some have nearly 20000miles and pads look thick like new. Low miles I would guess glaze. Take 'em out and scuff with sandpaper.
Rear noise may be glazed clutch shoes. That is done like glazed brake pads.
kneeslider
Re: Noises
« Reply #2 on: July 27, 2015, 02:06:00 AM »
Which pads are you on?
I changed my factory pads with GOLDFREN AD at 3000kms, now at 18000kms, they are almost to the backing plate.  Which means I only managed to get 15000kms out of a pair of front pads.
Will be replacing the AD with S33 Goldfren pads. Hope the HH rating will improving the braking.
2019 Yamaha X-Max 250
mnpugdog
Re: Noises
« Reply #3 on: July 27, 2015, 09:25:37 PM »
Only 4000 miles on them. The levers do pull back a little more but not bad. SO if it is pads on both ends what would be a good pad to replace them with then? I cna be a little heavy on the breaking so I certainly could be worn done al ready.
« Last Edit: July 27, 2015, 09:27:11 PM by mnpugdog »
kneeslider
Re: Noises
« Reply #4 on: July 28, 2015, 09:48:39 AM »
The scoot's pretty heavy so with a single sliding caliper at the front, a high fiction pad would certainly be favorable.
So, any branded pad with HH rating would be best IMHO.
Brands like Vesrah, Goldfren, EBC, DP should be safe bets.
mnpugdog
Re: Noises
« Reply #5 on: July 29, 2015, 08:33:13 PM »
So I want to do most of my own work on the scoot when posible. How hard is it to change the front pads? Do you need special tools or would what I have in the garage work? I do have the repair manual already.
kneeslider
Re: Noises
« Reply #6 on: July 30, 2015, 12:59:15 AM »
It's relatively easy, just need the tools.
Also, a torque wrench would be best to torque back down all the bolts to factory specs.
theb666
Re: Noises
« Reply #7 on: August 08, 2015, 05:19:30 AM »
Hey Guys.
I do not want to open a new topic just want to ask something about a weird noise that I have from today.
When I have a passenger with me during accelerations from 0kmh I hear a strange sound coming from cvt or engine I am not quite sure.
I think it is the CVT.
The sound is like a normal sound when accelerating but suddenly it goes deeper for a second or two and then back to normal.
Anyone have any idea what could this be?
I have 11500km belt was not changed or anything on the CVT.
Thanks,
TheB
Sent from my SM-N9005 using Tapatalk
