Author Topic: Loose Electrical Connection....  (Read 1039 times)
Urbestfriend
« on: July 28, 2015, 11:18:18 PM »
Before I rip everything apart,  My Red Charge light has been intermittently lighting going down the road from vibration.  Yesterday it finally lost all power.  I pushed it across some bumps and it finally caught hold,  but the light still flashed for a while.  Appears that once it's running it can keep itself going.  Anybody experienced this?
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Loose Electrical Connection....
« Reply #1 on: July 29, 2015, 04:14:33 AM »
I had the exact same problem on my GV 250.  The rear most nut on the ignition / spark plug coil is loose:
http://www.kymcoforum.com/index.php?topic=10385.msg108076#msg108076
PaulC
Urbestfriend
« Reply #2 on: August 13, 2015, 12:24:09 AM »
Must report this is absolutely crazy.  Didn't work on this until today.  started at the battery. Terminals clean,  battery fairly new.  Tightened the + terminal screw using an electric screwdriver.  It was 3 turns too loose.  Rode it thru the same route where I had the most trouble and it seems to be just fine.
mrbios
« Reply #3 on: August 13, 2015, 04:53:21 AM »
Good to hear.
PaulC
« Reply #4 on: September 03, 2015, 09:42:08 AM »
Ahhhh, that all electrical scooter issues were so easily sorted, eh?!
Well done.
