Author Topic: hard cold start  (Read 1163 times)
1martyg
hard cold start
« on: July 29, 2015, 09:12:44 AM »
I have a 2008 super9 ac 3 days ago I noticed was getting harder to start cold I changed plug, cleaned air filter, this morning took me 30 min after battery died kicking finally started noticed a popping out the exhaust for a few min leveled out I rode it 10 miles ran fine, let it sit an hour same thing, any suggestions will be greatly appreciated
1martyg
Re: hard cold start
« Reply #1 on: August 05, 2015, 02:26:26 AM »
noticed it won't start at all when there's a lot of moisture in the air, when the scoot is dry and the temperature is high it will start but not easily.
1martyg
Re: hard cold start
« Reply #2 on: August 05, 2015, 03:13:50 PM »
OK found 3 head bolts very loose tightened them put exhaust up fired right up smooth as silk.
mclark999
Re: hard cold start
« Reply #3 on: August 05, 2015, 04:12:50 PM »
Good troubleshooting.  I wouldn't have thought of the head bolts.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
Triesandluth
Re: hard cold start
« Reply #4 on: August 05, 2015, 08:25:55 PM »
Good deal!
Sent from my XT1080 using Tapatalk
1martyg
Re: hard cold start
« Reply #5 on: August 08, 2015, 10:14:16 AM »
Blew the base gasket out >:(
Triesandluth
Re: hard cold start
« Reply #6 on: August 09, 2015, 03:12:14 AM »
Bummer!
Sent from my VS980 4G using Tapatalk
