As a new rider to my DT 300 I've noticed that braking takes longer, and given the heavier weight and faster speed, the bike can skid more easily than my Yager. Yesterday I was coming back form a tutoring job in a section of Philly I'm not too familiar with. As I riding down a two lane road -- two going one way, and two the other, one known for its sharp twistys, and a flow of traffic speed 20-30 mph above the post 35, I was taking a sharp turn that ended suddenly at a traffic light moving from Yellow to Red.
I use both of my brakes when I come to a stop, and not letting myself panic I applied strong pressure, but not suddenly, or in a heavy manner. It was a reflexed I'd done a hundred times on my former, smaller scooter, but the DT was probably a 100 lbs heavier. Instantly, I felt the back tire begin to slide out to the left, then straighten out as I let up on the brakes, then re-applied a few times, enough to slow the bike. I went over the white, end-of-the-lane line by about a foot.
I know that 70% of my stopping power is in my front brake, but as I said, I use both of my brakes jointly when I stop. Are here conditions and situations were asymmetrical use of your brakes apply?
(I also discovered that my DT isn't the ABS version)
Second question -- have a lot today. I've recently starting using my right hand middle finger to hold my right (front) brake controls when I'm at a stop in traffic, or a light. I've noticed that on my DT that if I hold the left (back) brake control it causes my entire frame to vibrate from the engine. By using only my right hand middle finger I have more digits on my throttle, allowing better grip/control on the throttle and a better brake-to-power transition when the light turns Green or the car in front of me allows me to go. It's a big difference in the take off speed from a stopping position.
Does anyone do something similar to this?
-Wolf
