Author Topic: Agility 50cc lights keep blowing  (Read 845 times)
COFFTEA
« on: July 31, 2015, 06:09:21 PM »
Hi all.
My agility 50cc 2010 keeps blowing my sidelights both low and high beam and rear light(brake light is fine though)
Each time i put new lights in and put them on it is a few minutes then they blow again.
Does any one have any ideas what might be causing this i have changed the regulator rectifier behind headlight. I have looked for a bad ground but unsure exactly where i shud be looking.
Thanks everyone so much for any help given
tortoise
Re: Agility 50cc lights keep blowing
« Reply #1 on: July 31, 2015, 07:32:59 PM »
What is the charging volts reading?
! No longer available
COFFTEA
« Reply #2 on: July 31, 2015, 08:45:04 PM »
Ok i few readings
Battery when bike off around 14v
Battery when bike running around 18v
When bike is running i tested the volts coming from the sidelights and they read 0.5v same for headlight aswell.
The lights stay on for a few minutes then pulsate and then they die down to a very faint red glow of the wire inside the bulb.
If i turn the bike of and leave it for 15 minutes the exact same thing happens when they turn on then die down again.
Many thanks
JayAre
  • Jay Are
« Reply #3 on: August 04, 2015, 02:21:47 AM »
Anything over 14.5-15 & you will burn blubs & damage the battery. If the new regulator doesn't test ok there may be a bad connection or wire to it.
My wife never asked, " can you make it go faster?" until we bought a 4 stroke Moped. My reply, "yes dear"
2013 Agility 50 de-restricted with 72cc piston & head.
2-2005 Yamaha Zuma's 50cc 2 stroke bone stock
