Author Topic: oil questions  (Read 1003 times)
brankulo
oil questions
« on: August 03, 2015, 12:40:53 AM »
i recently purchased 2011 Like model. i am not sure what oil is currently used and weather or not i need to keep topping it with exactly the same oil. also is there a way to drain all the oil and start using the one i want?
i was recommended amsoil interceptor. also, any more specific idea for transmission oil? manual only says SAE#90.
thanks
beermak
Re: oil questions
« Reply #1 on: August 03, 2015, 02:31:53 AM »
I havent seen a like 50 in my life but i had my previous 2stroke scoot which when i had it i took the oil reservoir drained and clean it. Refilled with the oil i was going to use from that day on...
I used ipone racing synth 2stroke with amazing results. Almost no carbon builds less smoke and better response.
For the gear case get a 75w90 manual transmission fluid that its going to be fine. Either dino or synth..
