Author Topic: Wont start with left hand brake pressed only right  (Read 1140 times)
Chevy
« on: August 03, 2015, 09:41:11 AM »
My left hand brake wont start scotter only when i press right brake what could be wrong
« Last Edit: August 03, 2015, 10:02:47 AM by Chevy »
Andreeh00
  • Kymco Agility RS 50 4s
Re: Wont start with left hand brake pressed only right
« Reply #1 on: August 03, 2015, 09:45:18 AM »
Left wont work but only left does? What? If you mean that pressing the rear brake while trying to start wont trigger the start cant you just use the frontbrake then?
Chevy
« Reply #2 on: August 03, 2015, 09:50:54 AM »
Just worried if it wont start with right brake im going nowhere
beermak
« Reply #3 on: August 03, 2015, 10:48:26 AM »
Check if the brake light gets lid while pressing the leaver. If not check the small switch that the leaver has for that function
Chevy
« Reply #4 on: August 03, 2015, 11:15:39 AM »
Thanks beermak all fixed lose wire from handle to connector
Smithg27
« Reply #5 on: August 05, 2015, 03:24:37 PM »
I believe that is how its supposed to be (at least that's how mine is and always has been). Right brake is the only one that will start my A50
« Last Edit: August 06, 2015, 05:53:50 PM by Smithg27 »
bluesin
  • 2012 DT 300i
« Reply #6 on: August 05, 2015, 09:50:53 PM »
This happened to my husband on People S 250.  Left brake was acting like kill switch. Dealer had to repair ( still under warranty then ).
Hope this helps track down issue.
