Author Topic: 450i MXU Stalling  (Read 23927 times)
Oldfriend
Re: 450i MXU Stalling
« Reply #30 on: September 04, 2015, 12:33:37 AM »
Going up this weekend and going to change the tires and wheels. I have a regular floor jack. What would be good points to use? I was thinking in the back I'll use the hitch. Not sure about the front as it's not here to look at and I don't remember exaclty whats there. Thanks in advance.
Bratman2
« Reply #31 on: September 04, 2015, 02:30:33 AM »
Think I used the forward part of the hitch rear and right at the differential in the front. I have a 12" long 4x4 block I use with my floor jack so it might actually been lifting it by the frame. With the ground clearance and suspension travel they have a block is a must. I believe I also had to use a 1" decking board under the jack, that could have been something else I was jacking up though. Memory is not the best, lol! Don't forget pictures!!!
2019 UXV 700i LE Hunter
2014 MXU 450i
2004 Mongoose 90 (grandson's)
2010 Grizzly 450
Oldfriend
« Reply #32 on: September 05, 2015, 10:05:30 PM »
Just got back, it went well, have one small problem. I did'nt need the piece of 4x4 my floor jack had plenty of travel, good to keep around though. They look awsome!!!! Now the problem; one rear tire almost touches the outside edge of the fender when I sit on it. Theres about 1/4" clearance. I didn't have time to play with trying to loosen the screws on the plastic and see if I could shift it. Any ideas?
« Last Edit: September 05, 2015, 11:29:11 PM by Oldfriend »
Oldfriend
« Reply #33 on: September 05, 2015, 10:06:45 PM »
I know I have a lot of gear on it
Oldfriend
« Reply #34 on: September 05, 2015, 10:08:40 PM »
I use it more for utility purposes like cutting and skidding trees
Oldfriend
« Reply #35 on: September 05, 2015, 10:09:59 PM »
I lowered the psi to 5
« Last Edit: September 05, 2015, 11:29:26 PM by Oldfriend »
Bratman2
« Reply #36 on: September 06, 2015, 02:35:07 AM »
Oldfriend, they look awesome!! Did lowering the pressure to 5 give that much clearance? Only other thing I could think of is maybe up the preload a click or two on the rear shocks. I sure would hate trimming my new 4 wheeler for tire clearance! Didn't think about it at the time, the 25" tires I tried on mine already had over 702 miles on them. Then I am sure there is differences in width and height between brands. Did you notice any difference in acceleration, ride, etc? They really do look good!
2014 MXU 450i
2010 Grizzly 450
Oldfriend
« Reply #37 on: September 06, 2015, 03:03:33 AM »
They are 25x10x12. The stock ones were 24x10x12 so the width should be the same. i really think its the plastic alignment because its only one side. The left side is fine. Anyway, worsrt case is I have to trim the fender. Curious, what is the width on the ones that you tried?
Oldfriend
« Reply #38 on: September 06, 2015, 03:07:58 AM »
oh and the acceleration and ride felt different, but not bad or good, just different.
Bratman2
« Reply #39 on: September 06, 2015, 09:51:09 AM »
They were 25x10-12 rear from the Grizzly, but did have 702 miles on them. They don't look worn much though. Probably more a difference in manufacturing difference between brands I would guess. The Kymco factory Kenda 24x10-12 look nearly an inch wider when the two are parked side by side in the barn. Had a thought, wonder if you could elongate the holes a little on the fender trim, slide them a little further away? I might would investigate that before trimming. You don't need much it looks like. Plus, over time a little wear will increase the clearance. If you did have to trim it I would take my time and take off just an 1/8th or so and make it pretty. Probably could clean it up right much with a piece of sandpaper if you did have to trim it.
2014 MXU 450i
2010 Grizzly 450
Oldfriend
« Reply #40 on: September 06, 2015, 01:55:10 PM »
I'm a bit surprised that the manufacturers would make such a difference. They must know that it could be a problem on some quads. But it certainly seems thats the case. Anyway, I'll  play with it next weekend. I'm sure I can figure something out. The plastics are very flexible and I should be able to shift it or maybe like you said elongate the holes. I'll bring a dremmel with me. Trimming will absolutely be the last resort. Like you siad I don't need much. I did drive it but only up and down my driveway (it's 1,000 ft long) because I didn't want to take a chance going over any large bumps which could have made it hit. I wish I had the time to do it yesterday, but I had a lot of chainsawing that I had to get done as I was out of firewood. I'll post some pictures on all the trees that I have down from Hurricane Sandy, there has to be a hundred of them through out the property. Thanks again for your help.
Bratman2
« Reply #41 on: September 07, 2015, 12:47:38 AM »
You are very welcome! Us two have to help each other out. Maybe one day there will be three of us, lol!
2014 MXU 450i
2010 Grizzly 450
Oldfriend
« Reply #42 on: September 07, 2015, 01:35:33 PM »
I'm actually a little surprised no on else has posted anything here. At last count 768 people had viewed this thread.
Found a picture from Sandy. I have clumps of trees down like this all over the property. I was very lucky to not have one hit the trailer or sheds. One did get within 6 ft of a shed though. I've being cutting up what I can, but some of them are massive and are hung up on other trees. Too dangeous for me to handle alone. I'm good with a chainsaw, but I'm no expert!
Bratman2
« Reply #43 on: September 08, 2015, 03:03:17 PM »
We were spared Sandy. Living within an hour of the ocean I have had my fair share though. I despise them, make such a mess! Sucks how they uproot so many hardwood trees. Last chainsaw I bought was due to one several years ago. Made a huge mess at our place. Three trees down in the yard plus one big Bradford Pear tree split in half. Oh, and about a thousand limbs. Always wanted a big yard growing up. I have had 3 acres now for 35 years, not so much fun now, lol!
« Last Edit: September 08, 2015, 03:09:38 PM by Bratman2 »
2014 MXU 450i
2010 Grizzly 450
Oldfriend
« Reply #44 on: September 12, 2015, 09:42:58 PM »
So I fixed the issue of the fender being to close to the new tire. There is a large flanged Torx screw on the foot rest that holds it in place. Loosed it, push the plastic forward and bingo, problem fixed! Easiest fix of my adult life!
« Last Edit: September 13, 2015, 02:50:22 AM by Oldfriend »
