Did you miss your
activation email
Technical | How To
Locked rear wheel
Topic: Locked rear wheel (Read 595 times)
jawolf
Newbie
you are only old when you forget how to play!
Locked rear wheel
August 05, 2015, 04:14:50 AM »
Peoples200 has a locked up rear wheel. Any suggestions?
Carter Merz
Re: Locked rear wheel
August 05, 2015, 06:36:55 PM »
Sticking rear brake? Worst case, no final drive oil and seized up bearings. Sometimes a broken belt can jam up the clutch enough to lock up the rear wheel.
Back
