Author Topic: Downtown 300 6K service  (Read 561 times)
glaswurks
« on: August 06, 2015, 07:31:49 PM »
HEY BETTINANDLOSIN!
what will be required in a 6000 mi service on my 2013 DT 300? there's no way I'd do it myself but I always appreciate your thoughts
Thankyou
Tony
Re: Downtown 300 6K service
« Reply #1 on: August 07, 2015, 09:46:11 PM »
Hey Tony, sorry I just now saw this. The 6k as you might have seen in the owners manual is a Valve service, oil change, air filter check / replace, spark plug replace, final drive oil replace and general safety inspection of fasteners, brake pads, and any abnormal wear. Hope this helps anyone else around this mileage as well!
glaswurks
« Reply #2 on: August 07, 2015, 10:05:17 PM »
Thanks Carter
As always I appreciate your thoughts - I'll be in Friday for the service - it's nice to have someone in your corner who you can rely on. As I mentioned to you earlier I'm off to Canada as soon as I pick the bike up from you and I'll ride easy knowing you've checked it out. Any owners out there needing service and repair? - here's the guy.
Tony
« Reply #3 on: August 07, 2015, 10:19:26 PM »
Thanks Carter
Tony
Rock on Tony!!! I wish I had the time to go on awesome road trips like you, I'm lucky if I can get a 100 mile ride in on the weekends!!!
