Author Topic: OK i may have found an Engine! however i need help ...  (Read 1152 times)
htcneil2
« on: August 08, 2015, 04:56:49 AM »
I have an 09, fuel injected.
Found an 07 engine. can i make it work?
mrjlube
Re: OK i may have found an Engine! however i need help ...
« Reply #1 on: August 08, 2015, 11:00:30 PM »
Well,are you going to keep the engine with the carb? Or will you convert to fuel injection?
htcneil2
« Reply #2 on: August 10, 2015, 03:01:04 AM »
idblike to keep itbfuel injection
mrjlube
« Reply #3 on: August 11, 2015, 02:25:25 PM »
You  would have to remove carburetor and replace with throttle body off the 09. You will need  all wiring and such from the 09 . Probably  could be done,but sounds difficult.
« Reply #4 on: August 11, 2015, 04:12:55 PM »
Could be done, but like stated above a lot of work. Stator needs to come from '09, exhaust from '09, intake and cylinder head from '09, throttle body from '09 etc etc etc etc. And going back to the carb version will be even harder.
Jeopardy4100
« Reply #5 on: August 12, 2015, 04:55:34 AM »
Any machining needed for the fuel pump?
