Author Topic: Keep hitting kick stand in left hand corners  (Read 1469 times)
mclark999
« on: August 10, 2015, 03:30:57 PM »
Does anyone make a low profile kickstand for the People?  I've hit the kick stand in left hand corners a few times now and the last time it kicked the scooter out to the right and I ran up onto the sidewalk.  Was glad there were no cars parked.  I'd just take it off but I need it to fit it into the small space I have for it in my garage.
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
Re: Keep hitting kick stand in left hand corners
« Reply #1 on: August 10, 2015, 04:26:38 PM »
Two options; take it off, or get less aggressive in corners!!! I prefer to take them off!!
2wheelfun
« Reply #2 on: September 15, 2015, 01:22:09 PM »
Would taller tires help out BET?
mclark999
« Reply #3 on: February 24, 2016, 02:49:28 AM »
I don't really like the double stand so I'm just being less aggressive
Sent from my SM-G900V using Tapatalk
OEM 16mm carburetor
mclark999
« Reply #4 on: February 24, 2016, 02:50:07 AM »
Might help a bit
OEM 16mm carburetor
paceneedsstides
« Reply #5 on: February 24, 2016, 04:46:15 AM »
if you're that aggressive in turns drop the kick use the center stand lol
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
chaz35
  • old guy
« Reply #6 on: February 26, 2016, 01:56:15 AM »
I hit kick stand once going through turn because of bump.  No consequences, but slowed me down, I didn't like the feeling.  Also, done a few slides going through turns after hitting an unexpected slick spot.  After doing a few of those, I am more cautious now.  Cheers
