Did you miss your
activation email
Scooters - 125 to 300
Downtown 300
Clutch spring compressor
Topic: Clutch spring compressor (Read 1273 times)
An Orange Crush
Jr. Member
August 15, 2015, 04:42:47 PM »
I want to take my clutch apart and clean/lube it, does anyone use a spring compressor on it? The service manual shows one but I cant seem to find it anywheres, one supplier said the dont make them anymore.
2011 DT300i
2009 SYM HD200 (sold)
2009 Kawasaki Brute Force 750i
2023 Kymco AK550
A couple really nice shiny helmets
"I`m a man, but I can change. If I have to.
.....I guess....."
Carter Merz
Re: Clutch spring compressor
August 15, 2015, 04:48:13 PM »
Nawww just step on both sides and use the correct large socket. The spring isn't strong enough to overcome your weight on it. Once the nut is off you can use your hands to slowly release tension. Use mslossi mrg grease for the clutch, regular stuff will turn to liquid from the heat.
Adept
Empaticus Maximus
Full Member
August 16, 2015, 11:59:59 AM »
The center screw is a bigger problem... It was very hard to move it. The spring is not to strong, you can hold it with your hand...
I have a barely used (200km)14gr Dr Pulley rollers to SELL!! Send a PM if you interested in...
Carter Merz
Reply #3 on:
August 16, 2015, 04:17:25 PM »
Impact and the right size socket and the nut is easy.
Adept
Empaticus Maximus
Full Member
Reply #4 on:
August 16, 2015, 05:09:06 PM »
Quote from: BettinANDlosing on August 16, 2015, 04:17:25 PM
I think it is size 41 socket
but not sure. Huge..
2011 300i downtown 82,265 KM.
Reply #5 on:
August 16, 2015, 06:42:20 PM »
I seen one at the dealers and made my own, used a old disc brake to fit over the big nut,. on the other side I used a old bearing puller , to tighten it, a couple of straps on each side, weld it and it is done,. nice to have junk in the garage,.
Back
