Author Topic: kymco downtown125  (Read 779 times)
mevaser
kymco downtown125
« on: August 17, 2015, 05:55:08 PM »
hello.
a week ago i replaced my engine's tubes and ever since then my check engine light keeps blinking when I accelerate.
It starts showing me errors on the LCD monitor.
Re: kymco downtown125
« Reply #1 on: August 17, 2015, 07:27:45 PM »
What "tubes" did you replace? You mean fuel lines? If so did you use EFI rated fuel lines? The fuel pump puts out close to 100psi and the lines need to be rated for high pressure.
mevaser
« Reply #2 on: August 17, 2015, 10:40:31 PM »
sorry, i'm not so good with English.
i meant i replaced the trail tech stator.
