Author Topic: Belts  (Read 868 times)
Belts
« on: August 19, 2015, 12:47:58 AM »
I notice on my 50 cc  scoot that When using Gates belts I burn threw more. My scoot has 4,000 miles on it and have gone threw 3 belts the frist one lasted like up to the frist 3,000 then after that I went threw 2 more. I now have a power band belt on it to see if there is any dif. What do you guys think.is a power band belt better then gates.
Re: Belts
« Reply #1 on: August 19, 2015, 04:25:18 AM »
Gates belts suck. Oem are the best by far. You should get 8-10k out of stock belt....
Re: Belts
« Reply #2 on: August 19, 2015, 01:14:42 PM »
Starting to find that out. I also been going threw a few plug coils by NGK. I like my scoot but its the little things I have been finding out. I go threw the most of.So I now have a few extra parts just so I have theam. Don't wana be like a ford.....lol.  and be found on the rd dead...........
Chris0381
Re: Belts
« Reply #3 on: August 21, 2015, 09:57:56 AM »
I think Bando belts are what you will be better off with.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Re: Belts
« Reply #4 on: August 24, 2015, 01:48:19 AM »
      True that's what I have on it now. So far so good. The last belt even bent the face plate on the verator. So I had to replace that. I think bando belts give a little which helps.and the gates belts stay stiff and no room for play.
