Author Topic: Fender eliminating on Super 8...  (Read 394 times)
supremekizzle
« on: August 23, 2015, 06:54:55 AM »
So I've searched around and it doesn't look like a fender eliminator kit is readily available...go figure... It looks like us spec got the split turn signals. Does anyone know if the European and Asian tail lights are a direct fit as one unit? What parts will I need to order? Looking at the diagrams on Kymco parts online it's hard to ascertain exactly what I'd need to order. If anyone has any insight into the differences between the models could help I appreciate it! Thanks!
Edit: on further investigation it seems the spots are there, but the silver inner plastic on the inside that holds the bulbs would need to be swapped. Could I just buy one of those and reroute the signal wires, or would I need a new harness? If anyone could supply a part number for the plastic I'd give a million thanks!! :)
« Last Edit: August 23, 2015, 07:08:59 AM by supremekizzle »
