Author Topic: Scooter Died on Me  (Read 4918 times)
Vision
Re: Scooter Died on Me
« Reply #15 on: August 30, 2015, 11:30:34 AM »
THANK YOU JIM!
Just sucked on the vacuum line and the petcock worked.
Why is there no vacuum in the line to the petcock? The tube is in good shape.
Vision
« Reply #16 on: August 30, 2015, 05:30:52 PM »
The situation has changed.
Maybe multiple problems have led to where I am. Currently the carb has fuel but there isn't a spark. When the starter is hit, there is one spark and then, little to no spark after that. Also, on the spark plug cap, about 1/2 of that little area that protrudes at the end has melted.
tortoise
« Reply #17 on: August 30, 2015, 05:53:26 PM »
there isn't a spark
Replace spark plug cap.
Check ground wire connections.
Reference section 15 and test pulser coil.  Replacement resource.
« Last Edit: August 30, 2015, 06:27:59 PM by tortoise »
Vision
« Reply #18 on: August 31, 2015, 10:12:14 PM »
I replaced the spark plug cap/cable and I'm getting the same issue: one or little spark.
Does this mean the CDI is the problem?
Vision
« Reply #19 on: September 03, 2015, 01:32:10 AM »
The bike needs a new stator and CDI. From tow to purchasing future roadside assistance to getting back on the road I'm looking at spending a grand. Disappointing when so many people say their bikes go 30k with no problems.
jeeves
  • Dubrovnik, Croatia
« Reply #20 on: September 03, 2015, 01:02:44 PM »
Why both?
I understand that the stator can be the reason you have ignition problems , but what's the CDI got to do with it?
Agility City 125
