Author Topic: Question regarding a Cam chain Tensioner  (Read 784 times)
gingel
« on: August 26, 2015, 03:28:56 PM »
Hello,
I received a Genuine kymco cam chain tensioner, and i wanted to ask if it's supposed to have
a rubber cap where i marked in the picture.
Sym tensioners look almost the same, but they also have a rubber cap like here:
Thank you.
Re: Question regarding a Cam chain Tensioner
« Reply #1 on: August 26, 2015, 04:34:33 PM »
Some do some don't, it won't matter as long as you assemble the top cap WITH THE O RING!!!!!!!! Where the Philips screw covers the adjuster, make SURE you remove the o-ring from your old one and install it in the new one, otherwise it will leak a little oil.
gingel
« Reply #2 on: August 27, 2015, 09:18:31 AM »
Hi,  thank you for the answer.
Yes, i know about the o-ring under the big philips screw.
I actually have a SYM scooter, and i wonder if the Kymco tensioner will work in that engine.
The SYM tensioner and the Kymco tensioner look almost the same, only 1 difference, like i marked in the picture:
What do you think?
« Reply #3 on: August 27, 2015, 05:40:15 PM »
They will 100% interchange. The rubber plug does not matter. The tenssioner will interchange with 99% of scooters out there.
gingel
« Reply #4 on: August 30, 2015, 09:42:20 AM »
Thank you.  :)
I will try to install it.
