Author Topic: Problem with electric system  (Read 697 times)
ktienation
« on: August 28, 2015, 01:18:59 PM »
Guys,
Recently I am facing the following problem:
When the scoot is on idle, main beam are on and i.e. i turn on the traffic indicator and/or pull the stop handle, all the lights start do dim or even strobe (I know a little dim is normal but believe me, this is not normal).
I chacked the battery, when the engine is off it gives ~12,5 V, when on over 13,2 so i think its not the issue of the magneto.
Has anybody expected similar issues? For me it looks like there is a problem with grounding somewhere but maybe someone alredy has experience in this area?
Peter
Re: Problem with electric system
« Reply #1 on: August 28, 2015, 03:22:03 PM »
check your battery ground wire to the frame,.
ktienation
« Reply #2 on: August 28, 2015, 03:45:05 PM »
Thanks Dee De, sounds like a good hint. Is this cable visible / easy to find or is it hidden somewhere?
P.
« Reply #3 on: August 28, 2015, 09:36:02 PM »
  take the seat off, remove tub , follow the  black wire from the battery to the frame,
