That's a beauty! That looks like the stock front tire, if I remember correctly. Get some nice rubber for that, it'll handle 100 times better. You will need it with the parts you'll be adding.
I'm running the malossi bbk, variator, and clutch, a 19mm arreche carb, lightly bored out my intake, opened up the air box (check out the thread I made), and tecnigas pipe (bought used, model unknown). Running the stock gears, but I may get some malossi that I've seen. Not sure yet how it will perform. I live in the mountains of NC.
I've been unable to properly GPS it since my final set of upgrades, but I was following a coworker and he claims to have been doing sixty, primarily flat surface, wind not in my favor. I get it going on flats and have to back off because it seems like it won't stop climbing in speed and rpms.
Someone caught up to me at a Gas Station one time, said he was doing 55 and I was steadily pulling away. The speedometer barely sees numbers anymore lol.
Most important mod, tire pressure!!
