Author Topic: Tune Up guide  (Read 1245 times)
Scooterman007
Tune Up guide
« on: September 02, 2015, 08:42:36 AM »
Are you aware of a tune up guide I can download?  Just bought a super 9 that hasn't been used in a couple years.  It's in pretty good condition, but I think needs a minor tune up.  It came with a replacement spark plug and fuel filter.  I have a new battery in it, but it won't start.  I'm not a mechanic, but I am pretty handy and can follow instructions fairly well.
beermak
Re: Tune Up guide
« Reply #1 on: September 02, 2015, 12:41:10 PM »
Check for spark before... if theres no spark check plug, wire, cap, coil and cdi.
If theres spark check fuel system. Petcock, filter, lines and carb.
There not much that can go wrong... 0
Then id change transmission oil and brake fluid. Empty clean and replace oil reservoir and gas tank. Change or clean air filter. Change plug and gas filter. Inspect belt rollers and brake pads. Check lighting and tires.
Seems a lot but its very important to have a reliable and safe scoot.
Post a pic!!
big blue
Re: Tune Up guide
« Reply #2 on: September 02, 2015, 02:19:49 PM »
Hey Scooterman- Have a look at this website for a manual download. www.49ccscoot.com They have your manual. ;)
Re: Tune Up guide
« Reply #3 on: September 02, 2015, 03:33:45 PM »
If it's been sitting for two years it's going to need the carb cleaned on the inside. Plenty of videos of how to do this, but it's easy to screw up I suggest taking it to a shop.
0BARK4322
Re: Tune Up guide
« Reply #4 on: October 05, 2015, 11:44:32 PM »
I have the service manual but can't remember which site I got it from.....lots and lots of pages
ALL STOCK
