Did you miss your
activation email
Scooters - 50cc
PSI Tire Pressure accurate?
Topic: PSI Tire Pressure accurate? (Read 992 times)
NathanLocated
Newbie
September 02, 2015, 04:51:11 PM »
Page 20 of
http://www.kymcousa.com/owners/onroad/Agility50-125.pdf
the manual states 17.5 PSI Front and 32.0 PSI Rear.....is that correct for the stock tires when I bought my scooter? I just want to make sure I'm not running under inflated. I have the 2013 Kymco Agility 50 and I weight 200lbs (not sure if that matters or not as far as how much air should be put in them).
JayAre
Jay Are
Full Member
Re: PSI Tire Pressure accurate?
September 04, 2015, 08:25:02 PM »
I show 1.5kg/cm front & 2.0kg/cm rear for 1 rider in my shop manual. That's only 25% less in the front tire, you stated almost 50% less. 25% of 32 would put you at 24psi
My wife never asked, " can you make it go faster?" until we bought a 4 stroke Moped. My reply, "yes dear"
2013 Agility 50 de-restricted with 72cc piston & head.
2-2005 Yamaha Zuma's 50cc 2 stroke bone stock
Back
