Author Topic: People 50 2t lacks power  (Read 2317 times)
blufx
« on: September 03, 2015, 06:19:47 PM »
I recently got a 2000 People 50 2 cycle. It looks good and seems to run good, but 25-30 MPH is all it will do. I weigh in at 130lb. I pulled the cover and found the bushing on the variable pulley has been replaced with a smooth one. I removed the exhaust to remove the restricter washer, but there's not one in it. From what I've read, the way it is now, I ought to be getting 40mph. I think the CDI is stock, and I haven't taken the carb off to check jet sizes yet. I did measure the rollers in the variable pulley and found them to be bigger than stock. With this known info, what can I check and do to make it faster?
« Last Edit: September 06, 2015, 08:05:05 AM by blufx »
Looking back, when I said I wanted to be somebody, I should have been a lot more specific.
scooterdad2324
Re: People 50 2t lacks power
« Reply #1 on: September 03, 2015, 06:26:47 PM »
You can cut at the end of the cdi box with a hacksaw and cut deep enough until you see where you have cut a little copper wire. That's the rev limiter. It should touch close to 40 by doing that.
Sent from my XT1526 using Tapatalk
blufx
« Reply #2 on: September 03, 2015, 06:43:43 PM »
Thanks for that damn quick reply, scooterdad2324. I've seen a couple of pages covering this but wasn't clear if it was indeed for my CDI, and I couldn't make out how deep to cut. I know I'll see a copper wire, but at a 45 degree angle, do you have an approximate depth I need to go? I figure that will vary, it being resin filled, but do I need to worry about hitting anything else?
scooterdad2324
« Reply #3 on: September 03, 2015, 11:59:13 PM »
I cut mine only about an inch deep and you tube has some videos on this subject and I wouldn't think there is anything else in that area to worry about. But once again check the you tube video's. That's what I did before I cut into mine. Good luck and safe scooting my friend
blufx
« Reply #4 on: September 04, 2015, 05:20:45 PM »
I watched a couple of videos. When I sawed into mine, I didn't find a wire. I found a coil. Of course, as soon as I hit it, it was ruined. I need to find a replacement CDI for a 2000 People 50 2 stroke, USA model. Where can I get one fast?
blufx
« Reply #5 on: September 04, 2015, 09:17:03 PM »
Going back and looking under bright light, I never knew I went through the wire. I destroyed it. Can't blame anyone else. But for future reference, DON"T go too deep! There is  a coil there, and if you touch it, you can toss that CDI and start over.
Chris0381
« Reply #6 on: September 04, 2015, 09:27:42 PM »
Do a little searching, you may find a derestricted CDI replacement. I thought I saw some somewhere.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Chris0381
« Reply #7 on: September 06, 2015, 11:30:45 AM »
This is what I was referring to. Something like this.
http://www.ebay.com/itm/UNRESTRICTED-CDi-for-KYMCO-People-50cc-2-STROKE-Spacer-50cc-/181264909954
I'd contact Scooter Asassins and see what they can do so you dont have to be cutting a CDI again
Smooth Boss
Polini Variator
#95 Main Jet
blufx
« Reply #8 on: September 11, 2015, 02:16:27 AM »
Thanks for the link, but I had already found that one. If you scroll down to the compatible list, the People 50 has great big letters saying, "not for USA or Canadain scooters".
Bravin Neff
« Reply #9 on: September 25, 2015, 01:11:50 AM »
I have a hard time believing its the CDI box. In my experience, with a 2002 People 50 2T, between the variator pin and CDI box, the variator pin yielded far more speed gains than the CDI. I went from 26 mph to 45 mph (indicated) just from the variator pin, and the derestricted CDI box got me to 48-50. Something else is wrong.
