Author Topic: Seized Forks  (Read 1800 times)
relivingmyyouth
Seized Forks
« on: September 05, 2015, 09:29:21 PM »
Hi All,
A Quick sanity check needed.....
I have a project Super 9 which is or was going fairly well in terms of gremlins but I may have been defeated with seized front suspension.
The Super 9 has failed it's MOT on the front shocks not moving at all.
The bike did not cost a great deal so I'm undecided in terms of going for a fix or selling on as spares or repair.
Would anyone be able to share any experience on this please? Is it worth a fix, any tips for freeing them up, if even possible - penetrating oils etc or would it be a case of replacing? I'm not sure I could tackle the replacement myself, but there is a decent priced used set on ebay at the moment, but from a Super 9 that is 6 years older than the project bike.
I've not had a chance to properly look at it yet, but if there is a fix available, I'm willing to try.
If there is any advice available, I would be very much grateful to take it on board.
Thanks !!
Triesandluth
Re: Seized Forks
« Reply #1 on: September 05, 2015, 09:33:29 PM »
Oddly enough,  I just noticed yesterday that my forks are leaking oil from around the seal.  I've never dealt with suspension issues, so I hope someone will chime in!
relivingmyyouth
Re: Seized Forks
« Reply #2 on: September 05, 2015, 09:46:00 PM »
Fingers crossed! I've been thinking about it for a bit, considering a try with a couple of small diameter holes drilled in to help with any lubrication getting where it needs to, but I will hold off until I hopefully get some more technical or experienced views / input...
Triesandluth
Re: Seized Forks
« Reply #3 on: September 06, 2015, 09:05:04 AM »
I looked up a video on disassembling forks earlier.  If you haven't yet maybe you should check it out.  Might give you some insight.
Raindrop586
Re: Seized Forks
« Reply #4 on: September 06, 2015, 06:54:30 PM »
If your self lubricating the parts idea dont work . or if something goes wrong in drilling . brand new forks direct from Kymco is only 80 each free shipping .
Triesandluth
Re: Seized Forks
« Reply #5 on: September 06, 2015, 09:21:47 PM »
^^^ Nice!!
relivingmyyouth
Re: Seized Forks
« Reply #6 on: September 07, 2015, 06:45:57 AM »
Thanks for that, better price than I had thought.
Re: Seized Forks
« Reply #7 on: September 07, 2015, 04:59:02 PM »
Sorry I was late, new forks are honestly the cheapest easiest solution, but you CAN repair them. Remove, then unscrew the top caps (careful spring pressure) and poor e the oil fluid out, yours will be all water. If they are totally rusted you might need to get new valves and springs, obviously seals too. A lot of work when you can just pop in new ones in less than an hour.
relivingmyyouth
Re: Seized Forks
« Reply #8 on: September 29, 2015, 01:09:47 PM »
Sucess!!! Thanks all....little bit of penetrating oil sorted it with new seals and circlips.
Raindrop586
Re: Seized Forks
« Reply #9 on: September 29, 2015, 03:53:57 PM »
Good sh it
Triesandluth
Re: Seized Forks
« Reply #10 on: October 01, 2015, 09:32:17 PM »
Where did you order the seals from?
Triesandluth
Re: Seized Forks
« Reply #11 on: October 01, 2015, 09:32:44 PM »
And any tips on changing them?  I'm needing to do this soon
