Author Topic: Headlight bulb: LED ok?  (Read 2321 times)
RickEEE
« on: September 14, 2015, 09:45:01 PM »
Just pulled out a bad incandescent 12v 35/35 (BA20D) bulb from my Agility 50's head lamp.   Am thinking of replacing with this:  http://www.amazon.com/gp/product/B00HUOMYIU?psc=1&redirect=true&ref_=ox_sc_act_title_1&smid=A867P1BBKCZM8
I have searched and read with interest threads about rewiring new fixtures, but why, if this bulb works and draws a fraction of the current, produces less heat, produces more lumens and last 50000 hrs?
Any concerns or issues?
« Last Edit: September 15, 2015, 06:03:18 PM by RickEEE »
refrig
Re: Headlight bulb: LED ok?
« Reply #1 on: September 16, 2015, 09:55:39 PM »
read the Q&A.will not work on AC power
JayAre
  • Jay Are
« Reply #2 on: September 17, 2015, 01:27:17 AM »
Depends on your system AC or DC can you test it to find out? Or what year is your bike? I have a 2013 it's DC
My wife never asked, " can you make it go faster?" until we bought a 4 stroke Moped. My reply, "yes dear"
2013 Agility 50 de-restricted with 72cc piston & head.
2-2005 Yamaha Zuma's 50cc 2 stroke bone stock
RickEEE
« Reply #3 on: September 20, 2015, 05:42:31 AM »
2007. How would i test to determine ac or dc?
JayAre
  • Jay Are
« Reply #4 on: September 20, 2015, 03:29:35 PM »
You would need a multi-meter then connect it to the headlight leads see if it reads on the AC or DC scale. The old bulb may have writing on it saying 12v DC 35watt ect... that would solve the mystery
RickEEE
« Reply #5 on: September 21, 2015, 12:58:02 PM »
Pass the salt, this crow is not very tasty. Am now researching bridge rectifiers to see if i can salvage a $23 light bulb.  Will post what i discover.
RickEEE
« Reply #6 on: September 24, 2015, 04:24:36 AM »
After a fair bit of research, i decided to give up on the led head lamp idea. I know that others have installed bridge rectifiers to convert the ac to the needed dc, but I was not willing to go there.
« Reply #7 on: September 26, 2015, 12:47:04 AM »
you can wire it in from the stator.but make sure you put a fuse on the hot lead.
Redundant
« Reply #8 on: November 14, 2015, 03:06:17 PM »
I tried one of those, and even with a rectifier to convert AC to DC it burned out from overvoltage..
I am trying out one of these:
http://www.amazon.com/gp/product/B011NT1PE6?psc=1&redirect=true&ref_=od_aui_detailpages00
No problems so far, just not really brighter.  A lot of people are starting to use LED Spots aimed low, so I got some LED fogs that I will likely try out.
motman
« Reply #9 on: April 10, 2016, 10:36:53 PM »
Bulbs are DC! No problem with using a LED one, just order the correct fitment! All bikes use DC!!!
The stator driven from the crankshaft generates AC, it then goes to the rectifier to convert to DC before powering lights...
Some CDI units are AC some DC, same principle, when fed by the Stator it is AC volts, the CDI will then rectify Part of it it to DC to use for ignition.
